Questions about cruise control
librarianjen
Hi everyone! Two questions about cruise control:
1. I travel a two-lane road to work, it is somewhat hilly, but pretty flat for the most part. I normally use cc on this road, but should I not be using it if it's not completely flat?
2. I thought the 'accel' on your cc was supposed to let the car accelerate slowly - but when I use mine, it seems like my Versa speeds up quickly, and almost too abruptly. Is anyone else experiencing this?
Thanks so much,Jen
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
I use mine in quite hilly driving, although I might back off one or two mph on a steeper hill if the rpm's go to 3000 or more. (Mine has the CVT.)
If you tap the "Accel" instead of holding it, it should accelerate about 1mph. If I want a 3 mph increase, I tap it three times. Same thing to decelerate. Unless I'm trying to accelerate while already going up a hill, it always does so fairly gradually.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
I have the CVT and even in hilly areas, the cruise control doesn't send the rpms flying but when you hold the Accel button, I think it's normal for it take off like that. Every car I've used that button with does the equivalent of pushing the gas pedal about 3/4 of the way down and taking off.
librarianjen
Thanks for the replies! I should have mentioned in the OP that I don't have the CVT.
I appreciate the info!
KimberKenobi
Car: the Camel
yea... you have an S...
if you hold the button, it will rev higher and try to speed up quicker, but if you just tap it up then it'll speed up slowly...
