anyotherone »
https://forums.nicoclub.com/anyotherone-u21832.html
Sat Dec 15, 2007 4:46 pm
Intro: (long, you can skip this if you want) Well, this is my first post here in the VH section. I've built and run KA's, SR's, and an RB setup in my old s14, now I'm building a '93 s13 coupe with a VH45de. I picked up a '93 Q45 for $700 that still runs (has a miss in cyl. 2 though) my intention is to get the motor mounts fabbed up, get the motor mounted in the car and wired in, then pull it out and rebuild it since it has 220,000 miles on it and I am planning on a turbo setup of some sort, I'll make my mind up on single or twins once I see what kind of room I have to work with.
Question: I would like to run AEM EMS, as I have installed and tuned it on many different vehicles and find it to be a good system for the money. Obviously, there is no plug-n-play box for the Q45, so I will need to use the universal box, and wire it up myself. No problem, I have to wire the motor up anyways, using the AEM harness would just take some of the guess work out of that process. SO, does anyone know the specs on the VH's crank/cam angle sensor? Does it function similar or better yet, the same as the VG or RB sensor?
Any input or discussion would be appreciated.
