supra brit »
https://forums.nicoclub.com/supra-brit-u17265.html
Wed Dec 01, 2004 10:08 am
I finally got a job that will pay me money instead of peanuts, so I'm going to start saving up to turbo my KA...
But before I decide that's what I'm going to do, I just want to make sure it's a good idea.
My motor's got about 120k-ish miles on it. I noticed there is an oil leak in cylinder 3 - on the top of the plug, not where it fires...I have not yet had a compression test, but I will soon. I was told the leak is probably due to a bad valve seal...
Since it's pretty damn hard to find a KA with low mileage (especially because I would rather use a 91-94 as opposed to the 95-98), would it be ok to turbo a high-mileage motor? I don't plan on boostin higher than 10psi, and I'm going to do all the necessary upgrades for a turbo (pistons, injectors, fuel management, air flow controller, etc)...should I replace the head gasket as well?
Just need some suggestions before I start to get serious...thanks!
