fraz »
https://forums.nicoclub.com/fraz-u19354.html
Wed Sep 08, 2004 6:58 pm
the bolt holes are not tapped all the way to the bottom. that is why the studs sit at uneven heights.
You will also notice that the bolt hole in the head that is above the stud that sticks out, is higher than the other ones. what i mean is if you put a head bolt into the 2 front holes, you will see that one sticks out further than the other one.ARP says turn them in by hand is tight enough.
It is very expensive for ARP stuff here in NZ, so i managed to find some bolts from another model nissan. They were a little too long, so i got a bottom tap and tapped the holes till the tap hit the bottom. I gained another 4-5 turns of the bolt which is around 7mm and was enough for the bolts to pull up when using 2 washers
FYI, the thread on CA DE blocks is M11x1.5mm ans CA single cam ones are M10x1.5mm
