Questions about 248/248 cam swap
240sx_in_209
Car: 89 240sx.... 93 coupe
ok i just did the swap. everything good idles good and runs good all good but the only thing is now that i drive it and when i come to a spot the car dies. but it will idle fine when turned back on. my idle control valve thing was already acting up. and they were saying that it may be pulling to much vacuum and causing it to die. any help ppl
LoserCard
Car: Forest Green 1993 240SX SE Fastback
248/248 jacks your idle, so fix your idle control valve or up your idle.
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
248/248 is going to give you a lot more overlap, definitely going to mess with your vacuum at idle. Just use the adjustment screw on the TB to open the throttle plate a bit and you'll be fine.
240sx_in_209
alright thanks guys ill try that out
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Less vacuum btw, not more
