nuQ »
https://forums.nicoclub.com/nuq-u4532.html
Fri Jan 02, 2004 8:33 am
just got back from bennett infiniti in allentown pa, after getting a consult and power balance test performed. i've never gotten this done before, so i'm not sure if the results were what i expected. i'll let you guys decide if this sounds right. i told the service manager i wanted a copy of the printout and if it was possible to do the power balance test through all rpm's (a two man job). he wrote this down for the tech. as i was waiting he came in and said, running through the rpm's wasn't neccessary, the computer does this automatically. when it was done, the service manager told me everything looks fine, no codes, and all injectors were fine. i was very suprised, since i have the classic Q, 40-60 mph "burp" while cruising, which i figured would throw the---code 34---knock sensor. nothing. i'm almost positive they have never been changed,,,,,13+ years, and still functioning fine????? i spoke to the tech personally and he assured me that everything came back negative. the copy they gave me had this, i summerize;
----No DTC detectedPWR balance diag result OKreference datano.1 46rpmno.2 63 rpmno.3 57 rpmno.4 80rpmno.5 65rpmno.6 61 rpmno.7 55rpmno.8 63rpmbase datacmps-rpm(pos) 1126 rpmcoolan temps 179 degrees
work support self learning cont----97% R 96%monitorcmps-rpm(pos) 750rpma/f alpha-r 94%a/f alpha 95%coolan temp(s) 183 degreesO2S1 0.08v
thats all that was on the photocopy they gave me. make sense to anyone. anything seem out of wack. i'm planning on doing the plenum removal, and i've already purchased the KS'ers, still need to get the O2's.
any help in figuring this out would be greatly appreciated!!!! thanks, jeff
