question with removing the fan clutch...
naha_music
Car: '14 Ford Flex Limited
'05 Audi A4 Quattro
'02 Chevy Blazer 4x4
'99 Nissan Silvia Spec R
'86 Pontiac Fiero GT
'49 Ford F1 w/ Flathead V8
i had removed the fan and fan clutch today with plans on installing electric fans. after i removed the entire fan assembly, it left a hole (where the clutch used to be) in the block. do they sell plates to put over the hole? i need something to put over it cuz it looks like coolant runs throught it. any help in leading me in the right direction would greatly be appriciated.
Silvia007
Car: 93 Nissan 240SX SE Fastback
When you removed your fan and clutch, did any coolant came out? If what you are describing is correct... you probably actually removed the water pump also... not good. I hope you didn't run your car with it off.
Luke
Yeah, you only needed to remove the 4 10mm nuts located on the water pump pulley. If you removed something from the block itself, it was the water pump. You need to get some rtv silicone gasket maker and reinstall the pump! First remove the fan/clutch setup from the water pump pulley by the 4 nuts. Then reattach the pulley to the water pump without the fan using the same nuts.
DawgMode
Car: 180sx
lol...thats a first
