Question trunk wont close properly
brownbrix
I was wondering if anyone gets this problem when the hatch door is down and should be close but its not most of the time it close with out any problem but sometimes it doesnt? not sure if i should get it check or its how im closing it . and no when it does happen notthing is blockin the latch.
cireecnop1
Car: 2007 Toyota Touring Prius w/Package#5
It depends on if you are closing it hard enought. Sometimes the cabin can be a little air-tight, and when you just let it lightly drop closed, it bounces back and doesnt catch all the way.
Quotacious
Car: Rentals on weekends
Mine has this same issue. It seems to be much better, but there have been times when I had to slam the hatch down three times just to get it to latch properly. It will sometimes latch partially, but not all the way.
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
Mine does the same thing. There are two causes; latch, and the seal is very tight. The latch takes a second to "reset" after it is opened, and it does take considerable force to close the gate (tight tolerances, new seals). If the gate does not latch the first time, open it and allow the latch to reset, and drop it down from half open position with good momentum. I expect the hatch to close easier as the car "breaks in"
Quotacious
BBISHOPPCM wrote: I expect the hatch to close easier as the car "breaks in"
This seems to be the case, as where I once figured I looked quite the idiot, slamming my hatch closed several times, it now seems to catch most of the time. But, of course, I'm still slamming it down hard as I know it won't catch well otherwise.
versa6spd
Car: Versa S
Funny u mention that I had the same problem and then it wouldn't de-latch. I mean like i would unlock and hit the little rubber button but nothing. they ended up changing the whole mechanism .. according to the serv. manager it had "seized" up.
Scuba Steve
Car: 2007 Nissa Versa 1.8SL Technology Pakage 6 Speed, Black
I have the same problem but only in really cold weather -20c and or -4f and colder!! I slammed it so many times to no avail. I lubed the lock with teflon, worked that one time only. Next time I'll open one of the other doors and see if the air back pressure is the cause. So far no problems only when the temperature drops as I mentioned before. Fingers crossed!!!
marleyfan
Car: Black Versa SL, CVT. Tech Package, 35% Tint, Window Visors, Spoiler
Wow lots of pple with hatch problems. I'm having no problem at all. Closes every time. My mother in law has a Toyota Camry whose trunk I can never get closed. She has figured it out and can usually get it on the second or third try but I give up after about 10 tries.
