02pathy »
https://forums.nicoclub.com/02pathy-u44880.html
Wed Mar 25, 2009 4:34 am
does it go away after a while?does it go away when u step on the clutch?if it is a transmission bearing, then there r other bearings in the transmission as well, i think the one ur mechanic is talking about is in the actual transmission, if u answer yes to the above ?s then more than likely it is, keep in mind a new clutch too, that 500 is probably to take out, take apart n replace one bearing, unless its to take out transmission n replace throw out bearing.
fyi, if it is in the transmission i would replace all bearings in there, or u can't wait until he opens it up n tell u which ones u need or fine a jap trans and take chances with that
