question to 2007 and up Z owners
Nissan 350z / Nissan 370z general community discussion forum
07bluerocketZ
have you dynoed your stock or modified VQ35HR yet?or what numbers do you think the HR motor has stock to the wheels???
PerfectApex
Car: 2007 Grand Touring Coupe 350Z & 1999 Viper GTS-R (700hp)
07bluerocketZ wrote:have you dynoed your stock or modified VQ35HR yet?or what numbers do you think the HR motor has stock to the wheels???
Stock= approx. 260 rwhp with 15% drive train loss. Torque is more important which most 6 cyl. lack.
C-Kwik
PerfectApex wrote: Stock= approx. 260 rwhp with 15% drive train loss. Torque is more important which most 6 cyl. lack.
In internal combustion engines, Torque and HP go hand in hand. Increase torque at any given RPM and HP at that RPM will increase accordingly:
HP = (Torque x RPM)/5252
That being said, a low peak torque output in a motor is not all that meaningful either. Higher RPMs provide more mechanical leverage for a given amount of torque via the torque multiplication that occurs through the gears in a transmission. Ignoring any frictional/mechanical losses, 150 lb-ft of torque at 10,000 RPM will produce as much torque as 300 lb-ft of torque at 5,000 RPM if they are producing the same wheel speed. It's not by coincidence that each would produce the same HP as well....
PerfectApex
All this quote from some tech book and still does not answer the guys question!
TheHat
Car: 2007 350Z 6spd Coupe
I have seen 260 to 275 whp most of those being around 265.
C-Kwik
PerfectApex wrote:All this quote from some tech book and still does not answer the guys question!
Is this some kind of attempt at an insult?
bmike818
Car: 2007 Z
I don't think so. But you sure sound funny, because after a paragraph,you still didn't answer the thread starter's question.
I have seen numbers from 265 to 275 in different forums. You have to remember that there are numerous factors that affect HP. Humidty, the type of Dyno machine...in other words take all the numbers you see with a grain of salt. but don't worry, it's widely known that the new HR motors are special. High response...vroom vrooorrrrrm m<-theres an r for the reverb from the exhaust
...or maybe you secretly want an S2000. thats something a Honda owner would say.
C-Kwik
It wasn't intended to answer to OP's post. I was simply addressing a statement about the "lack of torque in a V6".
07bluerocketZ
i own an '07 350Z...now why would i want a ****ty honda????...Z 4 life
Return to “350z / 370z Discussion”
