Question...
Nissan dominates the drift scene - Always has, always will.
coheed
Car: poop
Hi! This is my first post, but I've read enough to ask a pretty legit question.
I am planning on purchasing a 240, and I heard that you can drift a stock ka24de pretty good. But, I want to know if it's better to buy an already swapped 240 or build of the ka24? I know this is a much asked question, but it relates more to the drifting side. I want to know what would be better in the long run for drifting. Any response to this would be greatly appreciated.
Thank you,Coheed
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
if you would be swapping anyway, and you have the money, buy a previously swapped one provided the swap is clean.... it will be cheaper than swapping yourself
crazymax
Car: 89 coupe
In the long run? I would start with a stock engine and progress as your skill does....
Nunook
I would get the kade and upgrade as you learn more. You may end up not wanting a turbo, or you might by the car with the swap already done and crash it cause you can't control it yet.
coheed
Car: poop
Thanks for the input guys! It's really appreciated. I think I'll go with just a stock ka24 and build it up as my skill groes, then if I want it, swap in the sr. Thanks again.
Anand
Car: 95 Nissan 240SX
wise choice..
If I could go back and do things over...
I would get suspension work, 2 way, bucket, wheels, all that first ...
THEN do a swap....
that would be the best choice..IMHO
coheed
Car: poop
Just another question, this one towards the suspension side of things...
Do you really need a $800-$1200 set of coilovers, or can you use a good set of shocks and springs? Either one doesn't matter, but I just want to see if I can save a little bit of money here or there.
SHIFTrl240
coilovers are considered better because they are usually alot stiffer than any shock/spring combo you can make(save coilover sleeves like ground control) they have matching dampers that are made for the spring that are mounted to them, not just mix n matched. if you really are serious about suspension, then get coilovers, if you just want to lower it and get a fair amount of performance increase, get the shock/spring combo
coheed
Car: poop
Yea, I was looking for the more performance suspension, and coilovers looked the best to me. Thanks for the reponse, and I think that's the end of my questions....for now muhahaha...juuust kidding.
Return to “Nissan Drift Forum”
