kamikazestorm420 wrote:another question ..
how much whp would i get if i have
downpipehighflo cat or test pipe3"exhaustblitz intakefmic
and pushing 1bar of boost ... if thats possible on the t25.
also wondering if i would need to change the maf if im going to run that setup?
and the max psi i can push on the t25 .. thanks
Those mods would probably net you around 250whp, but remember, the FMIC is NOT going to give you power, it will allow you to run higher boost levels.
1 bar is possible on a T25, but thats about its max. The MAF should be good until you go for a turbo upgrade.
