codyace »
https://forums.nicoclub.com/codyace-u28194.html
Thu Oct 13, 2011 9:55 pm
You're going VE turbo right? That's your goal
So if you go with a VE bottom end, and VE head you're going with a high compression, fragile, not intendend for boost setup
If you are looking for a killer turbo combo, look for a regular CP 8.5:1 or 9:1 piston(for a det) and then run the VE head for the greater flow.
In the grand scheme of things though, what is your goal? If you're looking for a generic street car like 98% of the forum, a VE head is overkill. If you're looking for a track slut who is all peformance, then go wild with VE.
