KGB »
https://forums.nicoclub.com/kgb-u78063.html
Fri Feb 13, 2009 1:52 am
It can. Here is how. The cranksshaft is the only part on an engine, aside from the oilpan, that sits any lower than it does. What it does is keep track of the position of the sensor. The crankshaft, so everyone knows where im coming from, is the one that the rods are connected to, which had the piston sitting atop, which has the fuel sprayed and ignited on it. The knock sensor which is, if not sitting on the head somewhere, not too far from the piston. This lonley sensor listens for bounces or disturbances in the cylinder walls.
So if so someone (sensors) is getting mixed communications with another person, the computer will tell you that something is up and that you have to check this guy out as well as this guy
