Jakw »
https://forums.nicoclub.com/jakw-u54333.html
Sat Mar 22, 2008 8:27 pm
If it's for sure a bad injector, that's around $800 aat a shop. I had nowhere near that much to spend, so I bought the tools to Dremel it for around $250 tops. I won't lie, it's kind of a a *****.
First things first (assuming you know which injector is bad), relieve the fuel pressure. Just start the car and pull the fuel pump fuse. It will run for a few soconds and then die. You also need to take off the throttle cable cover. Just pretty much disconnect whatever is in your way.
Then you have to dremel away at the plenum where it hangs over the one screw that you can't get off the injector cover. That's the easyish part.
Then, you need to get the soft, crappy, phillips head screw out. I got an impact driver in there and gave it a couple whacks. It was tricky getting the angle of the plenum grinding right so I could fit the tank-*** impact driver in there.
Then, you have to pull the bad injector. This parts sucks too. For some people, they just pop out with a tug on the connecting area. For me, I had to spray it down with some silicon lube and pull like all hell. I think I got my bigger neighbor to do it, since he could get better leverage on it.
Alright, so you're halfway there. Now hopefully, your new injector already has its new o-rings on it. If not, maybe soak the rings in a little oil to be able to slip them on. Once they are on, you need to get some vaseline and cover the o-rings with it.
Push the injector gently/firmly into place. This can be a ***** too. Some people have had luck tapping the top lightly with a hammer, but I fear cracking the plastic top. I recommend having your bigger neighbor push it into place for you, since he probably weighs more and can get better leverage.
Now you just need to secure the injector cover. Don't use those crappy phillips screws that are probably stripped. Take those to a hardware store and tell them you need the same thread and length but with an allen key head. Tighten the cover down, reconnect everything, and that should do it.
Any questions, let me know. And please, if anyone sees that I missed anything, make sure you mention it.
