question
daaracer
Car: nissan 240sx
anyone know around how much it would cost to get my ka24de rebuilt at some shop my car just died and im wondering how much im going to have to save up what happened is i was drove the car fine the day before then i parked and the next day the car wouldnt turn over and when i went to check the oil i took out the dipstick and oil bursted out the hole idk whats wrong can anyone help me out?
Eikon
Car: 71 240z, 93 Supra TT
wow.. I guess I can say that I've never heard of oil coming out of the dipstick before. I wouldn't even know what to guess is the problem. Perhaps one of the pistons shattered into bits and all those bits fell into the oil pan and that is taking up all the volume in the oil pan displacing the oil and the only place for the oil to go is out the dipstick tube... that's just a very wild guess though...
As for your question specifically.. Cost to rebuild an engine.. probably labor alone will be $1000+. The best thing to do is just find another used engine and drop it in. You can get a used KA engine for $500 or less. In fact, you are in Socal right??? I bet you could find another NICO member looking to install an SR20 or something.. You can get there engine and they will probably even help you swap it in. I'd keep your eyes on the classified section and perhaps the Socal regional forum.. post your desire and watch for engines for sale..
BUT first.. make sure the engine really is shot.. might be something stupid that I'm not thinking of that is actually repairable.. I'll keep thinking on it.
Eikon
ok.. an idea that might actually be a good guess...
If you had a bad piston ring, the air pressure built up on the upstroke of the piston would leak through and push down toward the bottom of the engine and crankcase and oil pan. With every stroke of the engine a little more air might build up underneath and eventually build up such pressure that it might be enough to actually displace the oil and shoot it out the dipstick when you pull the dipstick..
just an idea.
You could check around for prices of a rebuild.. but usually a head gasket job alone is more costly than just buying a new engine. So my previous advice will most likely still be the way to go..
daaracer
Car: nissan 240sx
thanks man i think i will do that keep an eye on the classifieds and what not. i did call places and asked for the engine but most of them were prety high mileage thats why i was wondering about a rebuild but i guess ill keep looking, thanks
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
This may sound kind of lame, but did you have an oil change recently. I have heard of shops putting to much oil into the engine. Check your oil fill cap on the valve cover. If there is oil pooled up in there, that could be the problem.
For what it's worth, hopefully that could be the problem, so you should just be able to drian the oil, refill it to the proper level and then do a compression check to make sure everything is in order.
Start simple and work your way up to more difficult scenarios.
