FrEaK wrote:are you stating that the Ka does not need to be built up to accept that much hp, it would need to be resleeves way earlier than the sr? and how many people are going to make 500 hp from either engine anyways... im saying, most normal people, would buy a turbo for the ka, and have to replace injectors, fuel pumps, ignition systems, etc etc, and your telling me that those are about the same as the sr? thats crazy... the sr can put out 250hp just with some minor mods... the cost of the sr and the minor mods, is quite bit less than a turbo, intercooler, new pumps, chips, injectors, etc etc... and no the sr wouldn't need new pistons, untill a certain point because of thier strength and beefiness....
what it all comes down to... is that it would cost more to modify your Ka into a relatively high hp range than a Sr. Why? because the Ka would need to replace all the stock parts almost, while the sr would only have to replace a couple... and minor ones at that...
thats what im saying....
There is a multitude of definitions for build-up. And no where in my post did I say a KA would not need a build-up. But at what point that build up is required is still being explored. Currently, 350 RWHP seems to be a tested HP that the KA can handle on stock internals.
I would agree that not everyone will be building a 500 HP car of any kind, but my point is that there is no reason the KA can not do it.
As far as cost, there is always a debate here. Depends on the prices you get and how far you take it. As an example, say you get an NSport kit($3500?) add a JWT ECU and 50lb injectors, boost about 15 psi...should net you over 300 RWHP...probably about 350. We'll say conservatively, that we spend about $5000 to get the KA to this point. To get an SR to that point we can consider $2000 for an SR, say $1500 for a Larger Turbo and manifold with associated piping to make it work, $1000 for a FMIC, and say minimally $500 for a fuel management upgrade using only larger injectors with a piggy-back computer. Funny, I'm adding up to about $5000 for each so far. And since I am estimating costs conservatively, the SR may actually cost more up to this point. Now lets say we build up even further. I would guess the KA will need upgraded internals first since it's running higher compression. Keeping in mind the KA is an iron block, the block should prove to be stronger than the SR block. Thus the need for resleeving the SR. That's not to say at some point, the KA may benefit from a resleeve if you get up to a point where even the iron walls of the KA begin to show it's weaknesses. But you will likely find the SR will need to be resleeved before the KA. But chances are most people will be content with the power we've reached so far. And so far both are coming quite close in terms of HP potential. As far as I can tell, there is a back and forth battle that can be won by either motor dependong on how they are tuned. And you have to remember, it's not necessarily all about HP either. Other factors of how the motor responds, where it makes power, and the car's intended use comes into play as well.
As far as the 250 you can make easy with the SR, sure...if you are content with that. I for one am looking for more. And stock KA's can see about 225 HP at only 7 psi of boost. And all the kits out there are overbuilt for the power they were designed around. Try to look at the big picture. In my opinion, the SR is a great motor, but way overrated in comparison to the KA. I will not argue about which motor is better, and that is still not my argument. But I really think you underestimate what the KA is capable of and the costs involved in buliding a fast car. Regardless of which motor you use.
