FriedEGs »
https://forums.nicoclub.com/friedegs-u28026.html
Wed Sep 12, 2007 7:36 am
First question: How far open should teh wastegate trap door open on a stock t28 turbo/actuator? The full 90 degrees? The FSM shows a picture of the door open 90 degree's. My actuator is NOT opening the door this much. It's maybe opening it about 25 degree's, or a quarter of what the full opening should be.
I did a test using my air compressor and a boost gauge. I pushed 7 psi of air into the wastegate and it opens nicely, but only opens the door a quarter of the way. (about 25 degree's) If I push 20 psi, I get teh same result.
I took off the rod from teh wastegate trap door and noticed that the trap door clearly opens atleast 90 degrees. (again, the actuator is not opening teh door anywhere near this much)
Do I have a bad actuator, or is this not a big prob for the door to open this little for our specific turbo and motor, at stock boost?
*S1 rb25det, stock t28, stock actuator, etc...
My problem is a fuel cut at full boost. . I am waay overboosting, close to 18lbs. of pressure, everything stock. I think I've narrowed the problem down to this wastegate.... I just need second opinions about how far these stock actuator's are supposed to open.
