Post by tracythedrifter » https://forums.nicoclub.com/tracythedrifter-u87644.html Thu Jan 31, 2008 8:19 am
Post by Hijacker » https://forums.nicoclub.com/hijacker-u9394.html Thu Jan 31, 2008 8:39 am
Post by tracythedrifter » https://forums.nicoclub.com/tracythedrifter-u87644.html Thu Jan 31, 2008 8:16 pm
OKay,thanks for the fast answer!!Hijacker wrote:SR clutch disc diameter is 240mmCA clutch disc diameter is 225mm (RWD DET)
The pressure plate will more than likely not bolt to the SR flywheel, although any machine shop could drill the holes and tap them for you.
I don't know if a CA flywheel would bolt up to an SR crankshaft, but I'm gonna go on a limb and say no.
In conclusion, I have no clue why anyone would want to put a CA clutch on their SR. The smaller diameter would translate to less torque capacity, and you really don't want that.
Just buy a clutch kit for an SR and call it a day.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
