typex240... you sure you want both front and rear have same brake power ?
Before we began:" Regardless of your huge rotor diameter, brake pedal ratio, magic brake pad material, or number of pistons in your calipers, your maximum deceleration is limited every time by the tire to road interface. " Which mean, no matter how much bigger or better your brakes are, your breaking capability are limited to your tires contact with the road before your wheels locked up and turn into little piles of molten rubber. Brake power x Tires grip = decerelation
ok, now picture this.In an emergency stop, you slammed your brake. Your car weight distribution goes from 50/50 ( ideally) to 65/35. Which mean your front wheel has much bigger contact surface compare to the rear.The contact surface increase = coefficient of friction of the tire increase too. Since you upgraded your front wheel brake, you are capable to stop better. Brake power x Tires grip = deceleration
But since you upgraded your rear wheel too, you rear wheel going to lock up before you rear wheel does. ( is either front or rear). And this going to cause you to lose the traction on the rear, which kinda like you are pulling your e-brake... if you are not travelling on a straight road, you are going to spin...
My recommendation. Replace your rear caliper with your front one, if you are going to upgrade your front to Z32 brake system.
