Question Regarding the use of a KA Throttle Body
Sil40sK
Car: '93 Nissan 240SX
'88 Porsche 911
'02 Ford Focus SVT
I just installed a KA24E throttle body onto my CA18DET and I have it all screwed in and hooked up minus the throttle position sensor. My question is should I use the TPS off of my CA, or use the one from my KA? If I use the KA one do I have to adjust anything special on it, or do any rewiring? Thanks guys
pulsar gtr
Car: NISSAN VEHICLES
It shouldn't matter which tps sensor you use. I believe both are identical in operation.
RafiPULSAR GTR
biosehnsucht
IIRC either DE or E is the same and the other not but I forget which. from what I remember the one that is different looks different.. but this is just memory. If it looks the same as the CA one it should in theory work..
rico05
Car: 1992 RMS13 w/ CA18DET
Just to be safe, I used my CA one when I upgraded to a KA24E tb.
float_6969
I'd use the CA if you've got it, otherwise, I think the E is OK.
Rusted_PS13
Car: 1991 Nissan 240SX
does changing the throttle body out make that much of a difference?
Mikey
float_6969
It flows way more air. If you look at the size if the butterfly on on the CA TB, and the KA TB, it's quite evident what the difference is.
Veen
Car: 1991 Nissan 240SX SE w/HICAS
Ok, I just put my KA24E on, and the coolant hookups are on the top side of the throttle body, not the bottom. It fits and all, but one of the hookups sticks up way past the hood. Is there any way to rotate that or just bypass it? It seems like a totally useless thing to cool off, since it already gets cool air and doesn't generate heat.
pulsar gtr
Here is how your rotate these lines.
get yourself a torch, heat the area where the coolant metal line comes out, don't heat it in one area, keep the torch moving around, for few seconds then with a pliers, you can easly rotate the lines. Done it many times, works good. But make sure you don't put too much heat as you are heating aluminum and can crack or melt if too much heat is applied.
RafiPULSAR GTR
Veen
Thanks. To confirm, I'm heating up the nozzle half that's sticking up, which frees it up and lets it rotate/twist/bend/whatever down? Or am I just heating the problem nozzle up and bending that down?
float_6969
the fittings are epoxyed into the housing. When you heat it up, you're allowing the epoxy to loosen up so that you can rotate the fitting inside the housing.
rico05
I cut em off the KA tb and plugged the ports up. No need for em unless you live where it freezes hard all winter long.
Akihisa
Car: 300zx, Italjet Formula 50Lc, Italjet Dragster 180
I cut the whole piece off the top so I could use it underneath the TB. It only took about 5 minutes with a saw and it looks good too.
Veen
I'll go melt the epoxy on them tonight and see if that works. Failing that it's hacksaw and plug time. I've started carbureted cars in sub-zero temperatures on a regular basis before, I think I can handle a non-heated TB on a CA. It does seem like a bit of a waste of space and hosing for an area where winter only hits for a mere four months.
jt15833
Car: 95' 240SX
does the KA24DE throttle body work?? ive capped my coolant lines to the tb so if those lines are up ill just chop em off
fanta
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Hmm....I may go pick one of these up at the yard this week. There's a couple KAE's in there...
float_6969
Fanta, that's the pic I was trying to find when I saw this thread!!!! Thanks man.
fanta
float_6969 wrote:Fanta, that's the pic I was trying to find when I saw this thread!!!! Thanks man.
I help when I can
slideways
Car: drifting/touge/auto cross
running the kae TB unit with stock cams is okay? not that it shouldnt be but are there any downsides?
