Yes, as a poor college kid taking 18 hours I would be perma-****ed.
The way I read the codes was to pull the ECU from the firewall, turn the diagnostic screw fully clockwise, wait two seconds, then return it to fully counter-clockwise. This caused the CEL light to begin flashing in a series of long and short flashes. These were the directions I received from the 240sx.org faq. And I interpreted them as a 33 and 103. Was that not correct?
I don't really understand how it could have broken while I was driving? I had driven the car the night before and had not had a single problem. I pulled into the parking spot and put it in neutral before shutting it off to close my sunroof and it idled fine before I shut it off, leaving the car in second gear. Could the chain have snapped during my starting attempt the next morning? If so, and the KA being an interference type engine, would I still have bent valves and hurt other components despite the car never actually being turned on?
No, I do not remember hearing the pump buzz with the key in the on positiong, although I did not specifically listen for it. Secondly, I purchased a 300zx fuel filter for the car, but I have not yet put it in. Do you think a clogged or old filter could keep the car from getting fuel? And this may be a stretch, but what about a clogged cat. converter? Could that keep the car from starting?
Thanks for your help.
