Papasmithnc »
https://forums.nicoclub.com/papasmithnc-u85333.html
Sat Sep 13, 2008 10:15 am
Looking at the difficulty of replacing an injector even without removing the plenum and such, I want to make sure that I have accurately identified the right injector that has failed.
In pursuit of that and as suggested I bought a mechanic's stethoscope. I tried using this diagnostic method but, with all the ambient noises of the engine, I could not hear clearly the clicking of the injector firing. Maybe I am not putting it in the right place but, I think I am.
Looking for another solution, I was at Advance Auto and they have this 20 some dollar kit that will let you know if the injector is firing. My understanding is, this will tell you if there is an electrical problem, for example bad coil, that will prevent the injector from firing. My concern is, will this tell you if the injector is just plugged up?
Basically I need some direction as to how to make sure I have identified which injector(s) need replacing.
Thanks,Dave in NC
