I'm still lurking around
I'm under the impression that a front clip is essentially that... you get the engine and everything that comes with it to make a complete swap into the engine bay, including the wiring harness but without a transmission.
A motorset would include the engine and transmission and possibly ECU, but pretty much nothing else. If you need hoses, or any misc parts, or even possibly a wiring harness.... you pretty much have to hunt them down, correct?
In which case I should be fine as far as the stock KA transmission is concerned, and it should bolt right up?
Am I accurate in this assumption?
