Dabizzo1 »
https://forums.nicoclub.com/dabizzo1-u52713.html
Thu Oct 23, 2008 9:40 pm
When I first started r&ring my 94Q 2 years ago, the egr passage in my plenum was carboned solid (it was a Dallas commuter car for a doctor before me). I have since replaced my entire egr system, including the egr valve, the egrc solenoid at the front of the engine, and the temp sensor. The temp sensor which should mount on the plenum itself gets carbon gooked up as well. The carbon acts as an insulator preventing it from giving a proper reading of the exhaust gasses coming from the egr, so a CEL is thrown. Check the electrical connector on the egr temp sensor for corrosion and after cleaning, apply dielectric grease to guarantee signal integrity....that goes for EVERY electrical connector under the hood. Even after a year of driving from my first cleaning with 8 brand new oem injectors, the carbon that accumulated in the 90 degree bend was amazing. I've heard of an annual decarbonizing of the intake recommended on this forum and I believe it. Depending on the mileage of your car, check the O2 sensors as well. The error code thrown for obd2 will point you right at the culprit. My criteria for a clean intake is very strict now as a result of this forum...listen to the hardcore veterans on this forum...they know what they are talking about. If the egr system and the O2 system are aok and you still get a CEL after reset, THEN suspect ignition or fuel. Keep us posted and good luck. Boris
