angrlam »
https://forums.nicoclub.com/angrlam-u24069.html
Mon Jan 03, 2005 3:55 am
Several weeks ago, my 1993 Infiniti G20 has been running a little rough. I had several things changed that I thought might be wrong with it, but that did not help. (i.e., fuel filter, air filter, spark plugs). I have noticed that the main problem is that when the car is in park or is idling at a stop light, the vehicle acts like it wants to die. It has only died on me a few times, but it always starts back up again. When I first purchased the car, it acted in a similar way, but only when my gas level was at a half a tank. I took it in to have it checked and I was informed that I needed a fuel sending unit. The mechanic told me that my car was not reading the gas level at under a half a tank. I never had it fixed because, one, the money, and two, the time. So, I just keeped my car filled on full at all times and never left it get below a half a tank. Like I mentioned, until several weeks ago, my car has been running a little rough, but is driveable. A friend told me that my car might need an Oxygen Sensor. I understand that is a very expensive part and I am not prepared to spend that kind of money until I know that is what will fix it. I have also been told that my fuel injectors might be clogged. I have been told so many different things. If someone could help me, I would really appreciate it. Thank You.
