Bandit240 wrote:Well if the 200SX has IRS it wont work. All Datsun/Nissan trucks have soild rear axles. There is s Subaru rear diff that will work in Datsun/Nissan cars, but i dont know what it is off the top of my head.
it is solid (live) axle, so it does not have IRS. I've heard about the subaru lsd,but I was under the impression that only works for IRS.
so in knowing that my 200sx has solid rear, what do you think about the 23vs 29 spline axles, and as far as the differential carrier?
also, a quick question... the dogleg transmission that came in S10 chassis 200sx,I know it is sought after by 510 guys, but what are the advantages of thedogleg shift? I'm not sure if I understand correctly... but dogleg means itdoes not use a clutch to shift... its like, viscous shift?? anyways, you knowbetter than I do, thats why I ask.
thanks bandit, appreciate the help. any info about the rear end would behelpful... I'm really trying to avoid going with a welded diff.
