so do i stick the multimeter needle on the plug that is circled in red?? as on the attached picture. do i need to keep the engine running when taking the readings?krayton wrote:the empty plug is for the AUTO transmission. the plug below it is for your actual TPS
if u wanna check the voltage, id say just throw the multimeter on it.
