s14noob »
https://forums.nicoclub.com/s14noob-u20904.html
Mon Apr 02, 2007 1:43 pm
i posted this over at ka-t.org but not getting as much help as i expected. hopefully it works out better here.
basically the car is stopped, in neutral, warmed up and has a normal idle of 750-800rpms. i rev the engine to 6000rpms and i hear the bov and the engine stalls. i expected this because my bov vents to atmosphere so i'm not concerned about that. next i rev to about 2500-3000rpms bov DOES NOT vent and i stall. is this normal? i even disconnected the bov vacuum line, temporarily sealed the end and i rev the engine and the same thing happens. i'm running a enthalpy tuned ecu with z32 maf, deatchwerks 650cc injectors and open greddy type-rs bov.
my next problem is my bov is venting before reaching 7psi under wide open throttle. i have it set on the hardest setting and it's still venting while i'm building up boost. could it be that i have too much vacuum pressure running to my bov causing it to be so sensitive?
i really hope you guys can help me out with this. thanks
