--> nexus, when I first got mine it had those same shifting issues. I ran codes, did trans diagnostics, replaced fluid and filter, tested the tps for dead spots, and checked connectors, no improvement. Believe it or not, after cleaning the years of buildup off of the throttle plates the shifting smoothed out a great deal. Can't explain why, but if you haven't already, I'd give it a try.nexus08 wrote: I have an auto NA, and do not like the transmission at all. It shifts as if it thinks I'm trying to run a 0 to 60 test every time I take off (i.e., it doesn't want to shift until somewhere between 4 and 5,000 rpm). I can force it to shift most of the time by letting up on the gas a tad.
If I had to do it over again I'd of gotten a manual. FTR, I have driven manuals most of my life. When I got this car, I was looking to try something different.
MrFeesLaw wrote:Manual all the way. The Auto trans is de-tuned for the turbo model, and the auto trans holds a lot less power than the manual (which, in case you didn't know, is the same trans out of the r32 and r33 skyline). So if you are looking to modify a car to make a lot of power, then don't bother with the auto, because you will end up having to remove it for the manual as soon as you modify anything.
On most older model cars, the auto actually is less efficient than the manuals, and don't use the power as well. Most people think that new "Automatics" are better on gas than new "manuals", but the problem is, that many new "Automatics" are not actually auto transmissions. They are electronically shifted manuals. This is why the new "autos" are more efficient and shift faster, is that they are actually still using a clutch. It is just electronically controlled. There is no torque converter, or trans cooler.nissanfreak12 wrote:MrFeesLaw wrote:Manual all the way. The Auto trans is de-tuned for the turbo model, and the auto trans holds a lot less power than the manual (which, in case you didn't know, is the same trans out of the r32 and r33 skyline). So if you are looking to modify a car to make a lot of power, then don't bother with the auto, because you will end up having to remove it for the manual as soon as you modify anything.
This is not entirely true, the auto is a pretty strong trans, but like any auto that is older with a lot of miles it will have issues. Is it the best option for the TT Z, no, but that is a personal preference That being said an auto can out shift a manual any day. There are also a lot of upgrades for the auto that can make it shift quicker, have a higher stall for quicker 1/4 mile times. Same mods, same HP, same everything between a manual and an auto, the auto will always win in a straight line. Mountain runs, thats a toss up.
TT autos are not detuned so to speak, yes they have 20 hp less, but that is to keep the rpm's in the optimal range so there is not any lag between shifts. If I remember right the auto does have a quicker 1/4 mile time than the manual, or just a hair slower.
So, to the original post. What are you looking for in the car? How good are you at driving manual? How much traffic are you going to sit in? Drive both, you will enjoy the manual better, but its hard to just say one is better than the other.
