question on wider tires
Fenvy
Car: 2005 350Z Base 6MT
now that I drove 225/50/15 all around for abotu 2 weeks now, I can say that iit's kind of cool.
I noticed that the traction has increased, I can go faster on turns at speed I was in fear of before when running 205/55/15 on the same make/model of tires. However, at the same time, it feels that the car is harder to turn now... kind of confusing, is that why people run staggered setup where the front is thinner than the rear?
vvaffle
Car: 1991 240sx base hatch, 2009 WRX
Yep. Ss front tires get wider, they get harder to turn. Besides for that, having the same width tire all around results in understeer for some people, not all though, and I'm not talking just 240 specifically. If you still have your old tires try running them up front and see how you like it.
sensibleS13driver
narrower tires up front will definitely increase understeer(but it will be easier to steer, and staggering is not really neccesary unless you have a lot of power in the first place.
Dattebayo
I am told you should not run anything highter than 205's. 225's have a tendancy to rub in tight turns or something?
sensibleS13driver
just take out the fender lining and then rubbing is a matter of offset not width, up to a certain point of course, like 245 maybe, and anyways, a little fender rubbing never hurt anyone.
ArticDragon192
Car: 91 Z32 2+2
225s will rollover. It'll cause understeer during the turn since the tire will rollover and actually be riding on the sidewall.
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
i have 225s and they dont runover but then again i run 225 40 18's
ArticDragon192
Car: 91 Z32 2+2
K, lemme rephrase. 225s on stock rims will rollover. However, if the rim is widerthat around 7 inches, then the sidewall wont be as thick and there shouldnt be any rollover.
Fenvy
what's roll over? is that like cingular roll over minute?
anyways, I have 15x7 wheels with around +15 offset, it rubs the inner fender lining when I turn all the way. The rub is insignificant, just barely a touch
hybrid_flyer
well thats easy just remove the lining, it doesnt do much unless you live in an area with a lot of snow
xyoufailmex
Car: 1990 240 FB
Rollover is where the tire actually rolls over, the edge of it... Anyways, wide tires are the single most overrated hyped topic on this board.
Loveless, I have 15x7.5 +20 offset wheels and Im running 195/60/15s on em. Good bit of oversteer, and still plenty of grips around the turn... plus I only have a KA so theres no point in some big tire.
