crzycav86 wrote:If you're using it with e-manage ultimate, just get the sensor. You won't need the display.
Just make sure the sensor you buy is compatible.
he would still need the controller though, just not a display.
if you are justing looking for something cheap with an analog output, check out the base zeitronix. should be ~280 for the controller, sensor, and cables/harnesses.the lc-1 is another basic wideband setup that you should look into.
