virus77 wrote:8.5 in front with 23 offset running 235-40-18. 9 in back with 40 offset running 275-35-18, had to hammer roll the fenders on all corners to make it fit. The pictures of my car are old with different tires and no spacers in the front. Unless you are running a 275-285 in the back get a lower offset.
Actually, you're running the exact same tire setup I'll be using...235/40/18 up front and 275/35/18 in the rear. I figured I'd have to roll and possibly pull the rear fenders, but didn't expect to have to do the same for the front. Did you also pull out all the plastic fender lining in the front wheelwells?
