C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Aug 27, 2008 7:52 am
The gear oil used in the pumpkin is only there to lubricate the spider gears and the ring and pinion gear. The gear oil does not affect the viscous coupling. The viscous coupling in the differential is sealed and uses a much much thicker silicone based fluid. The VLSD and open diff Nissan uses in the R200 are not much different. The VLSD simply has a viscous coupling attaching 2 of the internal spider gears together. The operation you describe is what happens in a LSD that uses clutch packs. The VLSD uses no clutches and the discs within make no contact, ever.
To the OP, the VLSD is quite transparent. This is because the resistance is based on a fluid so the slip/lock mechanism is gradual (relatively). By contrast, clutch LSDs will generally remain locked and breakaway once it hits the the threshold for slip. Helical LSDs need to load up slightly before the locking occurs so there is an ever so slight delay in operation. I occassionally heard some noises out of one of these as it locked up. Clutch types can make noises during operation as well. The Really big disadvantage for a VLSD is that the lock-up is quite mild. Much better than an open diff, but don't expect much help if you get stuck in the mud with it. In fact, I had parked on a steep driveway that was caked with dry mud. One tire had some traction, but the other had none. I had a very difficult time getting the car up the driveway as it kept spinning only one wheel. But this isn't a situation most sports car drivers will be contending with on a race track or in spirited driving so its not a huge problem. But the resistance to spli is lower than you might find out of a mechanical or helical diff.
