Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Wed Feb 04, 2004 3:39 pm
I doubt they'd see the dent unless it was severe. Putting a bare wheel on the balancing machine will give you an idea if the wheel is bent or not.
The tension rod is attached to the lower control arm and the subframe. On the subframe side of it, there is a big ***, liquid filled bushing. If that bushing is cracked, leaking, or empty; it will cause vibration issues. The tie rods are what steers your car. Attached to the hub is your tie rod end. If it looks cracked, corroded and leaky, it should be replaced. Also, if the tie rod boots are damaged (on the inner part of the rod towards the center of the car), your inner tie rods could be damaged as well.
