EW »
https://forums.nicoclub.com/ew-u28959.html
Tue Aug 19, 2008 5:52 am
If you look at most amps manufacturers "peak" ratings, they are a full double to triple the actual 12.5V RMS rating. That is why I'm saying that MTX is not using "dynamic" as "peak" since the power increase is only printed as 30% or so. It is not out of the realm of possibilities to get 14.4V at the amplifier but it is certainly optimistic in most cars. For SOME regulated amps, there will be little output variance from 10.5-14.4V (depending upon brand, model, etc) so it is not as important to have 14.4V for full output. However, the closer to 14.4V you have at the amp, the less amperage the amp will pull, the cleaner the output will be, the more power output there will be, and the cooler that amp will run. The electrical system must be in good condition for the best performance from your electronics. As a consumer, you should only be looking at the 12.5V RMS output rating since it will be the most realistic.
