At WOT, 16 psi-ish I see 38-43% duty cycle depending on the weather. I was hitting 95% when I first got my Power FC on the stock turbo and injectors at only 10 psi in the winter time.93Niss240 wrote:highmile hatch..... what duty cycle are those 600's at? im hoping my 480s will be enough
You wont get 300hp on stock injectors and stock maf. You're lucky to break 250 on stock injectors and stock maf, even with a T28.TKOcrewSR wrote:I have an s13 blacktop with an s14 t28 ... stock injectors stock s13 maf i am at about 95% ... 300-320 fly hp than about 270-80ish is about that.
With stock injectors you wont make those numbers though. Do you know what maf he was running, if he was running one at all.DrifterProdigy85 wrote:Guy close to me did 300whp 315tq @ 20psi on his S14 T28. Had AEM EMS, 550cc Injectors, and Stock Cams. Theres no doubt in my mind he coulda did 320whp with a set of 256 or 264 cams.
