Question on s14 lsd?
Nock Out Puppet
Will a s14 lsd fit in a s13? I need to know if it is a direct bolt in, and do i need the axels or stuff like that. Also do I have to change it from the s14 to s13 housing or will it work like that?Yhanks.
Nismo_Freak
Car: 89 Nissan 240SX
Swap the diff. cover... and check the driveshaft length, ABS shafts are shorter.
Nock Out Puppet
Other than that it works?Thanks Alot.
Nismo_Freak
Yeah, reverify that your halfshafts are the correct bolt pattern as well.
Nock Out Puppet
Thanks. Ill check them and hopefully everything works out.
