Question on Repainting??
ursus
Car: 07 Nissan Altima Sedan SE 3.5 6MT
I was wondering what is involved in painting a bodykit to another color.
Do I have to rid of the old paint first? and how? sanding? or other methods?
I am not going to prep/paint the kit myself but I want to get an idea of what is involved so i wont get "jipped" by the bodyshops.
Any help greatly appreciated.
DaCoupe
Car: 2009 Nissan Altima Coupe 6MT, 2006 Ninja ZX-6 636, 2011 Mustang GT 5.0
Step 1-Clean your car thoroughly to remove all dirt and grime. Then use a good wax and degreaser on it to remove all residue so that just the paint is on the top level.
Step 2-Remove everything that will not need painting so you have to do as little masking as possible. This includes bumpers, lights, door handles, grill and the windows if possible.
Step 3-Sand the old paint with a dual-action orbital sander. This will help make the new paint adhere better to the car body.
Step 4-Inspect the car for any damaged areas that need replaced or filled in with body filler. Repair as needed in these areas.
Step 5-Mask off areas where you don't want paint. Use plastic or newspaper for this and tape that won't harm your car. This includes windows, whether you took them out or not. Whether or not you removed the windows you don't want paint on the interior. This also includes where your antenna is and if you have a convertible or sunroof.
Step 6-Wipe your car down once more to make sure no residue from sanding or repairing remains as this will leave imperfections in the paint job.
PaintingStep 1-Spray your car with a good primer to help the new paint adhere to the car.
Step 2-Sand the primer after it dries to even out the finish. Use a sanding block not just sand paper. Coarse sand paper should be used to make the high spots even while not damaging the low spots.
Step 3-Spray a second coat of primer on and sand it with a 600-grain sand paper for a smoother finish.
Step 4-Remove the masking and wash the car to get rid of any dust in areas you can not see on the car's finish. These can leave bumps in your paint job otherwise.
Step 5-Remask the car and wipe off again.
Step 6-Spray the basecoat of paint keeping the spray gun perpendicular to the section you are shooting and holding it about 10-12" away from the area. This will ensure an even coating.
Step 7-Spray the top coat on the car and let the car dry.
ursus
Thanks for the detailed reply!
