You also drive a S14, which is NOT the same as a S13 w/ SR20det. Yes the wobble will work to loosen the bolts, but you will still need to drop the sub-frame unless you like damaging your firewall wrestling with 150lbs of transmission and cursing because the bolts hit the firewall before they come all the way out. Please read what the Op has listed as a car before posting miss information.s14ben wrote:A 24" extension with a wobble on it will hit those bolts from underneath. I've had my transmission out several times without messing with mounts
done it with a KA in an s13 also.BTW that transmission is only about half that weight. eat some wheaties.240life wrote:You also drive a S14, which is NOT the same as a S13 w/ SR20det. Yes the wobble will work to loosen the bolts, but you will still need to drop the sub-frame unless you like damaging your firewall wrestling with 150lbs of transmission and cursing because the bolts hit the firewall before they come all the way out. Please read what the Op has listed as a car before posting miss information.
First off punk I just got out of the military and am 6ft 220lbs I don't need wheaties. I have also done it with a KA in the car. Second of all the KA has more room then a SR which makes it possible. The last time I checked a KA is NOT a SR20DET....next time your in MAine look me up I got a few things i would like to show you, punks14ben wrote:
