question on rb engine swaps
A home for 1983–1989 300ZX owners!
kusakari_boy
how do there transmission fit the driveshaft
icice9
Car: 280ZX
your going to need to have a custom driveshaft made...
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
yup, you'll want the yoke from the rb driveshaft (which I believe is the same as the ka) and you'll want the end piece that fits your diff's pinion flange, not all r200's use the same pinion flange
if you have a shaft with the proper pieces at both ends that simply needs shortened, expect about $100 if you have to make one from scratch expect $300-400
Racinjitter
Car: 1988 300ZX RB25DET
1988 300ZX Shiro Special
evildky wrote:yup, you'll want the yoke from the rb driveshaft (which I believe is the same as the ka) and you'll want the end piece that fits your diff's pinion flange, not all r200's use the same pinion flange
Yup to add to this the rb20det yoke is the same as the ka yoke. The rb25det yoke is the same as a z32 yoke.
Return to “300ZX (Z31) Forum”
