JETPILOT wrote:would those cams work on all VQ35DE engines? i have a 2008 Nissan Altima coupe V6 with the VQ35DE in it. also, what does it mean by "non-rev-up"? also i heard your idle will be a little more rough. it wont be like those old school muscle cars that pretty much die if you don't give them gas right? around what RPM would it idle at? would it idle something like when your engine is cold in the morning?
On a rev-up motor there is variable valve timing on the intake and exhaust side.
On a non-rev-up motor there is only variable valve timing on the intake side.
There is also some differences in the intake manifold.
Whenever you do a cam swap, and you are going more aggressive you will pretty much always have to put stronger retainers and valve springs in. You could put the cams in there by themselves, but if you wanted in the be a reliable install you will want the retainers and springs. Labor is also ridiculously expensive for a job like this. I would say if you bought a set of NISMO cams, with valve springs and retainers, and then got someone to put all that in. It would be in excess of three grand, thats unless you get the hookup for parts and labor.
