I recently picked up a 99' Infiniti QX4 as my long commuter and outdoor activity transportation. I had the experience driving this car long time ago and fell in love with it. Since this was an used vehicle, some issues I've noticed so far and hoping you guys can provide some guidance
1. The middle strip in the cluster (yellow circle) should show the gear I am in correct? Since mine doesn't show the gear, does that mean the bulb is out? or it does not use the bulb but a soldered LED?
2. the climate control lower set of buttons (yellow circle) for defroster, interior circulate, temperature change, fan speed, etc.. are also out of light at night time (when headlight is on). Do these use bulb that I can replace them? or I need to change out the entire climate control unit?
Thanks in advance for the help.
