^haha. yeah it does make my head hurt. my bf and i were quite perplexed about the pricing scheme for the nismo unit, helical unit and the viscous coupling.tenkawa_akito wrote:i don't question nissan's pricing scheme. it makes my head hurt too much.
i managed to get ahold of the guts of an S13 silvia k's VLSD for around $150. The thing is in perfect shape and only had like 80k km on it. I think nobody was bidding on it because it had to be shipped from japan for a pretty penny.
all in all, I plan to upgrade to a helical unit in the future (when i actually have money to spend again).
Also, please don't call anyone retards on the boards. Some people will be less likely to respond, and the likeliness of the thread finding it's way to the netherworld are much higher.
yes. sky already stated that earlier. sometimes the prices of a JDM unit are good enough that you take it over sourcing a USDM unit. I bought mine from a silvia because it was such a good deal. All said and done, i paid around $300 with shipping included. All I needed was to source some output shafts. $90 later I had stubbies and an extra set of axles out of a CA powered silvia.spider_slayer wrote:weren't vlsd's and anti-lock brakes sold as a package on the usdm 240's?
You can't put regular diff fluid in there if that's what you mean. Since I had mine installed at Nissan (sidejob) they don't have 'lsd' fluid, what they do is add in some BG LSD goop into the diff, then fill it up with the regular diff fluid.Badfish wrote:I found these links extremely helpful, SimpleEnigma, in addition to the ones Sky posted in the beginning of the thread.
http://www.ka24development.com/vlsd.html
http://www.zilvia.net/installs/lsd/lsdswap.asp
I went with a JDM unit as well because I found a 91 r32(RWD model) vlsd with axles no one was bidding on. $323 shipped to my door last friday.
Unfortunately, it started snowing today. With more to come. So I think my car will be coming off the road and apart for the winter. I already opened up the VLSD, and it doesn't look beat on. Output shafts are VERY hard to turn by hand in opposite directions.
Is it recommended to put the LSD additives in for viscous differentials, Skydragoness? I wasn't sure.
Are you sure that different fluid is neccesary? Everybody has told me that since the viscous coupling is a sealed unit, that no special fluid is neccesary. I have never heard of anyone adding anything other than typical diff fluid to a VLSD.skydragoness wrote:You can't put regular diff fluid in there if that's what you mean. Since I had mine installed at Nissan (sidejob) they don't have 'lsd' fluid, what they do is add in some BG LSD goop into the diff, then fill it up with the regular diff fluid.
Redline has fluid for "special rear-drive racing differentials" I also found this stuff which may help http://www.redlineoil.com/prod...ID=20naed240sx wrote:Are you sure that different fluid is neccesary? Everybody has told me that since the viscous coupling is a sealed unit, that no special fluid is neccesary. I have never heard of anyone adding anything other than typical diff fluid to a VLSD.
Ah! That's kind of exactly the same stuff Nissan uses in the BG brand.sensibleS13driver wrote:
