deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Thu Jan 19, 2006 4:02 pm
You should always get the cylinders properly bored, new sized pistons (oem equiv. or other), cleaned/polished crankshaft and new bearings at a minimum when rebuilding you short block.
In order to get anything near a proper crosshatch on the cylinders for proper ring break in you will be taking to much material causing to wide of tolerance for a cast piston. With a forged piston, you have more tolerance to work with generally but you will still be reaching the wide end of the specified range. Combine this to the fact that the effort involved in properly honing (to provide wide tolerance and untrue cylinder) cost more than the $50 to get the block properly bored.
You will have a longer lasting, more dependable, and more powerful engine if you are serious about doing it right.
If you do want to just re-ring and hone the cylinders, be sure you are aware of the proper cut and crosshatch that is necessary, and that you are not using chrome moly rings.
