Code: Select all
Key pos Wire Voltage------------------------------------------------OFF BAT 12V START 0V ACC 0V ON 0V
ACC BAT 12V START 0V ACC 12V ON 0V
ON BAT 12V START 0V ACC 12V ON 12V
START BAT 12V START 12V ACC 0V ON 12Vhuguetpj wrote:This for installation in my 93, it should give you some help:http://katcostarica.240sxonlin...r.htm
Now.. if you have a Voltmeter it's quite simple. Open up the steering wheel column as I did and using the chassis as ground look for the wires as follows:
Code: Select all
Key pos Wire Voltage------------------------------------------------OFF BAT 12V START 0V ACC 0V ON 0V ACC BAT 12V START 0V ACC 12V ON 0V ON BAT 12V START 0V ACC 12V ON 12V START BAT 12V START 12V ACC 0V ON 12V
Then connect the GND to any screw you can find. The steering column one work fine. Just to make sure measure resistance from your selected screw to the chassis.
