fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Sun Jul 17, 2005 5:48 am
I wouldnt- the sensors are most definitely very different. In case you didnt already know, the KA has 2 "water temp sensors" on the water pipe there.. one of them is a "wideband" version which reads the temp to the ECU for things like cold idle etc. The other (flat plug) is a simple 1-wire "narrowband" hookup just for the gauge in your dash.
What I would do is leave both of those sensors in, and install your autometer sensor above them, in the hole you use to bleed/burp air from the coolant system (about an inch higher than the other water temp sensors. Just pull that 10mm bolt out, redrill and retap for your sensor's thread, there ya go!
