I've already read all I can on the subject and really appreciate the sticky and all the messages I've read. Tonight I've jacked the truck and tried to look on how to do the job and I'm a bit confused
Let's say I'm on a lift (I will go at a nearby garage to lift it up just to simplify the job)
What I understand is that I should :
- Remove the wheels
- Remove the rubber bumper completely using a 12mm socket after having soaked it in WD40 (Or should I leave just an inch of the rubber thing ?)
- Pass the air pipe in the bolt hole having enlarged it to 3/4 of an inch
- Route the air tube through the frame (Do I have to drill a hole in the frame ??) to where I want to put the valve
- Squeeze the air lift tube through the coil and plug the hose.
- Make sure all is airtight, put some pressure, test it with soapy water
- Put back the wheels
- Drive home then have a beer.
I hope to work on it tomorrow evening so any insight would be really appreciated.
Attached are some photos of what I was looking at. It seems quite obvious when I read the posts here but when I try to figure out how to do it I'm pretty much confused...
Thanks in advance, I owe you all already,
Jon
