Yimu »
https://forums.nicoclub.com/yimu-u41759.html
Fri Aug 11, 2006 8:50 am
I am changing the TPS coz seems my car is not idling really well during start. TPS had a history b4 and i replaced with a used one, when TPS was bad, the car had black smoke and very rough idle. Then when i replaced with a used one, these problem got away but the idle started to be fluctuating just when i start the car. It will fluctuate and then everything is fine after 5 sec, also feel the vibration under my seat when i shift to D, however this vibe will go away when i shift to N or Pany ideas tech?
Really need your advice
thanx a lot
