Question On Gauges
infinitiI35man
Ok I just I plan on getting 3 Gauges for my I35... I just put in a Air/Fuel Ratio one and briged the o2 sender to the white wire on the front o2 sensor... It moves around abit and when I floor it it goes to rich.. Its a narrow band so is it going to move that much.. or did I attach it to the wrong wire???
And I was going to get Oil Temp or Oil pressure and Fuel Pressure.. which ones are good choices???? any other suggestions
Thanks for the help!!!!!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Is this on a stock car?If it's an auto, trans fluid temp would definitely be one of my choices. Oil temp or oil pressure would be the other Probably oil pressure. Unless you're messing with FI or hardcore tuning I don't see much reason to bother with fuel pressure unless you just want another gauge for the heck of it.
Oil pressure and trans temp I think is what I'd go with.
nismo1219
Car: '12 Nissan Altima 3.5SR
'99 Nissan Maxima GLE
i have the autometer a/f ratio, transmission temp & a volt meter since our cars dont come stock with one. i know, the volt meter may have been a dumb choice but i get tired of having to guess whats wrong when the battery dies...this way i would know its the battery. not that it even happens that often but whatever...different strokes for different folks. however, i have had these for about 2-3 yrs now just sitting in the closet cause i cant find anybody who knows how to install them.
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
unless you have a wideband o2 sensor your afr gauge is a worthless expense - doesn't work with narrowband sensors.
